TeryonTheHuman
PC Specification: GTX 950, AMD Fx6300 Windows 10
Can't adjust stream audio balance?
Tue May 01, 2018 11:38 pm
Is there seriously no way to adjust how loud the game volume is in relation to your microphone? The audio balance settings only work for basic recordings not livestreams which is leading to a bad stream and even worse recorded footage because you simolu can't hear my commentary half the time. What's the deal here guys? Am i glossing over this setting or does it literally not exist? If so streaming with commentary is useless.
Re: Can't adjust stream audio balance?
Fri Jul 13, 2018 9:47 am
Please download the latest 3.1.6 version of Action! To set the audio balance for streaming, first please select Video tab and configure audio level between microphone and system sounds. It should also apply for streaming. Please have a look at the screenshot below:
audio balance.png (124.36 KiB) Viewed 12375 times
In case of problems please provide us here the screenshot of your mic and audio settings.
