Oliver
PC Specification: I7, Fury, Win 10 64
Action! crashes on startup, Win 10
Wed May 09, 2018 1:46 pm
Action! 3.1.2 crashes on start using Windows 10 64 bit, AMD Fury, both with all updates. Long time user, it used to run fine without ever crashing until this week. Tried uninstalling (incl. Regkeys), reboot, reinstalling, did not help. Also tried rolling back to older versions (3.1 and 3.0), did not help either. I cannot run the application at all anymore. Please advise, thank you!
Windows application log event is as follows:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2018-05-09T05:29:16.786893000Z" />
<EventRecordID>18423</EventRecordID>
<Channel>Application</Channel>
<Computer>xxxx</Computer>
<Security />
</System>
- <EventData>
<Data>Action.exe</Data>
<Data>3.1.2.0</Data>
<Data>5af1fa4f</Data>
<Data>c0000005</Data>
<Data>000276d0</Data>
<Data>794</Data>
<Data>01d3e756aa8a1b8c</Data>
<Data>C:\Program Files (x86)\Mirillis\Action!\Action.exe</Data>
<Data>d4ce5d03-eade-4cb4-8dbd-ee363d52a9f2</Data>
<Data />
<Data />
</EventData>
</Event>
Re: Action! crashes on startup, Win 10
Tue Jul 10, 2018 8:26 pm
Hello Oliver,
Did you upgrade Action! to the newest 3.1.6 version? Could you check if the version 2.8.2 starts correctly?
