Crusage
PC Specification: AMD FX 8350 ,GTX 1060 6gb, Windows 10
I cant import avi files into vegas pro like before.
Fri May 11, 2018 11:13 am
The files im trying to import are .avi files, but in vegas pro it says the file type is unknown and when i try to import it it says there was an error with the codec. I know action uses its own codec, but i managed to fix this problem before, i just dont remember how. I remember that i had a problem when it was mp4 files, so i started recording in AVI, which them seemed to fix the problem for me. I was able to just drag and drop and be able to get the 2 audio tracks and video without any problems. But for some reason it doesnt work. I have no idea how to fix this. I can play the files just fine in Splash 2.0. I dont want to convert the files bcs that would take so much time since they are so big, and i tried converting one of them, but that made this distorted square in the middle of the video for some reason.
Re: I cant import avi files into vegas pro like before.
Fri Jul 13, 2018 11:29 am
Could you please upload sample video that does not work for you?
