gordonsmith789
PC Specification: gordonsmith789
Video's in slomotion
Fri Jun 08, 2018 1:58 am
I tried the trail version of Action (Version 1.0.1 and 1.1.0). And the program works very well. But when I try to export a video file, the new file that is created play's in slow motion. And when I try to import the video file into Adobe Premiere Pro CS5, Premiere Pro crashes.
Does anyone have the same problem?
Re: Video's in slomotion
Fri Jul 13, 2018 8:40 am
first try reinstalling Action!
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
