mozkan007
PC Specification: Core i7-3610QM GeForce GT650M Win8 x64
Fracture from corner to corner on movies (Edited)
Thu Jun 14, 2018 9:11 pm
Hi, I am using Splash player v2.1.0 on Windows 10 x64 and my graphics card is GTX 1050 and everything is to be updated and working smoothly. Coming to my problem, when I watch any video format in Splash player there is always a fracture from corner to corner on the screen and it is seen very easily during watching action scenes. But there is no problem on the other video players like mpc. I can not share with you a picture of the problem because it just happens very fast and there is not enough time to capture it. Please fix this blasted issue because it is very disgusting to watch a movie on this player with this problem. I hope you can fix it quickly. Thanks.
Edit: I found the culprit which causes this issue. When I disable to motion2 60fps feature, this problem does not occur. I guess, there is a compatibility problem of the motion2 feature related to GTX 1050 graphics card. By the way, the fracture can be seen easily when I make fast forward a video file. But as I said, there is no problem when I disable the motion2 feature.
Re: Fracture from corner to corner on movies (Edited)
Thu Jul 12, 2018 6:40 am
Hello, does the issue occur for every video file?
mozkan007
Tue Jul 17, 2018 2:56 pm
Yes, it occurs on any video file.
Wed Jul 18, 2018 5:51 am
Please try updating your NVidia drivers. Could you run Splash on Intel graphics processor and see if the issue persists?
mozkan007
Wed Jul 18, 2018 8:57 am
My nvidia driver is up to date and there is no problem with intel graphics card and this problem just occurs on nvidia graphics card.
mozkan007
Wed Jul 03, 2019 7:31 pm
Hi again,
My problem is still continuing on the latest Splash player v2.7. I just wanted to report you. Will you provide a solution for this issue on the next updates of the product? Thanks.
Return to “Splash 2.0”
