Miwoo
PC Specification: i7 7700k - 1080 GTX - Windows 10
Action! 3.1.6 launch issue
Mon Jul 09, 2018 4:02 pm
I can't launch the software.. "the procedure entry point was not found in the dynamic link library action_x64.exe" , something like that.
The splashscreen stay and nothing... need to end the task in the process.
Please fix this..
Regards,
Miwoo
Re: Action! 3.1.6 launch issue
Wed Jul 11, 2018 6:37 am
Please fix this..
Regards,
Miwoo
Please try the steps below:
- open command prompt as an administrator
- in command prompt window type: sfc /scannow
- press enter and wait for scan process to complete
- restart PC
Miwoo
Thu Jul 12, 2018 10:19 am
Before to do this, I reinstall the 3.1.5 version, and no issue... I think the problem is the action launcher.exe
Miwoo
Thu Jul 12, 2018 10:42 am
This solution doesn't work
Fri Jul 13, 2018 5:45 am
Click on, "Start Button".
Click on, "Run".
Declassifiedzz
PC Specification: Windows 8 / i7-3770 / AMD Radeon HD 8760
Thu Jul 19, 2018 8:16 pm
I have the same problem.
I run it from steam and the same message appears and it freezes there saying ''loading modules''.
Any solution?
Fri Jul 20, 2018 5:46 am
Any solution?
Also please provide us your PC DxDiag report.
86GQZ3E
PC Specification: intel pentium, geforce 920m, windows 10
Sun Nov 18, 2018 5:06 pm
I have the same problem, when I start Action, it freezes on the "Loading modules" screen, and then close itself.
Here is my DxDiag report :
https://pastebin.com/raw/D0aUqDff
Tue Nov 20, 2018 7:13 am
Download these NVidia dirvers: https://dlcdnets.asus.com/pub/ASUS/nb/D ... 538402.zip
Start installation, select custom installation and uncheck all components leaving only basic graphics driver. Select "perform a clean install" option and install drivers.
See if that helps
