Zenth815
PC Specification: Amd Fx 4350, Readon R9 200 Series,Win 10
Action Not Running But Gives Error
Thu Jul 19, 2018 11:39 pm
I have had this problem once before but i temp fixed but now its back when i start up Action it gives me a error and it says The procedre Entry point could not be located in the dynamic link libary C;program files (x86)\Mirillis\Action!\Action_x64.bin
Here's a video on the problem i have made. (i had to use OBS to record that because of action done OOF)
https://youtu.be/npPmc3eERIg
Re: Action Not Running But Gives Error
Fri Jul 20, 2018 5:48 am
please provide us your PC DxDiag report. It will help us investigate your problem.
Click on, "Start Button".
Click on, "Run".
Zenth815
Sat Jul 21, 2018 10:26 pm
So it wont allow me to add a text file so i added it to be a doc file thats only way i can add it.
https://drive.google.com/file/d/1l-aEfi ... sp=sharing
Mon Jul 23, 2018 4:16 pm
Hello Zenth815,
This is a very strange problem and it might be related to some kind of antivirus software blocking Action! from working. We can see that you have Malware bytes installed on your system. Can you temporarily disable the antivirus or add Action! to the antivirus white-list (exclude).
Let us know if that helps.
Zenth815
Tue Jul 24, 2018 11:57 pm
This Did not Help fix this problem it still gives me the same error
Wed Jul 25, 2018 5:52 am
Please open command prompt as an administrator and type: sfc /scannow
Wait for scan to complete and restart your computer. See if that helps.
Zenth815
Fri Aug 10, 2018 3:01 am
when i did that it said this is that good or bad
Fri Aug 10, 2018 6:19 am
This is good for your computer but not that good for your problem.
Please update Action! to the latest version. If the issue persists then run Windows in Safe Mode and see if Action! works then.
Zenth815
Sun Aug 12, 2018 3:04 am
i did that but it did not work so i installed it and reinstalled it and it worked and just to make sure it worked for good i closed in completely and open it agin and it worked
