Blank
PC Specification: Intel i7 - 7740k GTX 1070 Ti Windows 10
Can't find "Record microphone into a separate track" option
Sun Jul 29, 2018 7:59 pm
Can't find "Record microphone into a separate track" option, can anyone help? I have the most recent version installed.
Re: Can't find "Record microphone into a separate track" option
Mon Jul 30, 2018 6:33 am
Hello, this option can be found in Microphone Settings. To open Microphone Settings click settings button next to selected mic device.
The attachment micSettings.jpg is no longer available
schmigel
PC Specification: AMD FX 6300, GTX 970, Windows 10
Thu Aug 02, 2018 10:58 am
I enabled this option but theres no way I can find the audio file. (if it exist in the first place)
In the Audio tab I selected a folder for audios, but nothing changed.
schmigel
Where is the separated audio file?
Thu Aug 02, 2018 11:09 am
I want to record the audio as separate file,
but there is no way I can find where is the audio file,
(when I disable the option for separated record, I record the audio with the video. so no problem with that) :roll:
Fri Aug 03, 2018 6:12 am
This option is called "Record microphone into separate audio track" not the "Record microphone into separate audio file".
Microphone is recroded into the same file but on different audio track. If you put your recording into video editor you will see two separate audio tracks. Also, when watching your recording in Action! Player press A key to change the active audio track.
If you want to record microphone in separate file then go to Settings -> Audio, enable AUX audio feature and select your microphone.
