triggerboi
PC Specification: i5 6500, RX480 8GB, 16GB, Windows 10
How to stream in stretched [4:3] (1440x1080)? [Solved in the next update.. probably]
Wed Aug 15, 2018 6:08 pm
THIS IS NOT A TUTORIAL, THIS IS A QUESTION
So recently I've purchased Action from Steam and I've been wondering if there is any way to stretch native resolution 1440x1080 to 1920x1080.
Before you tell me, stream is always 4:3 if the game is recorded 4:3 (so it's impossible to get rid off black bars), almost every single Fortnite PRO player has this res and they stream in FullHD. The thing is, probably most of them use another wellknown free-to-use software (i don't want to make an advertisment), but I hate it so I purchased this and I am satisfied, if I do record I record in 1440x1080 and then I stretch it in software for editing.
Is there any actual solution? I've tried to look it up at forum but haven't found anything.
Re: How to stream in stretched [4:3] (1440x1080)?
Fri Aug 17, 2018 12:17 pm
Hello triggerboi,
Thank you for reporting this problem. We will force 1440 x 1080 resolution not to be recorded as square pixel but in 1920 x 1080 aspect ratio.
This should fix the problem. We will add this feature in the next update coming in few next days.
Thanks again!
triggerboi
Sun Aug 19, 2018 1:23 pm
Hello triggerboi,
Thanks again!
Oh my god. YOU ARE THE BEST RECORDING/STREAMING SOFTWARE EVER! It took you little bit too long to post my problem, but I get it and I think you're the only team who could respond AND ACTUALLY LISTEN TO PEOPLE! Like... why aren't you more popular than the free competition... oh I get it now. Cuz it's free and people don't actually want to pay for better things. I hope you're going to be more popular one day. GL!
Re: How to stream in stretched [4:3] (1440x1080)? [Solved in the next update.. probably]
Mon Aug 20, 2018 8:09 am
Hello triggerboi,
Thank you for your lovely note. The team here at Mirillis is thrilled to hear such a good feedback! We always try to listen to our users to provide the best solutions and features. Thank you again for sharing such a positive experience. You made our day! :)
Regarding the popularity, we are planning a big change in our model that, we hope, attract more users. 8-)
Yungn3
PC Specification: i5 8400 gtx 1050ti w10
Tue Dec 04, 2018 1:37 am
Is there any way you could make it so you can pick your base resolution and then a resolution that it records to. For example Using 1444x1080 but it records to 1920x1080?
triggerboi
Tue Dec 25, 2018 10:13 pm
yeah would love this feature too
xingyuboss
PC Specification: i7, amd 530
Sat Aug 24, 2019 10:22 am
it's not working for me, I'm recording at 1024x768, there's the shit black bar. I try everything, it just not working
Karbust
PC Specification: Ryzen 7 2700X, RTX 2070, Windows 10
Record 4:3
Tue Oct 29, 2019 4:45 pm
I bought action today on steam. I've used it before sometimes.
I usually play 1080p, but csgo I play 1024x768 (4:3 Stretched).
Is there any way to record without black bars or that's the only option?
Thank you
