tecram
PC Specification: Athlon 4850e (2.4 Dual Core), ATI HD3200
System requirements for Picture2.
Mon Nov 15, 2010 10:32 am
I'm interested in Splash PRO and Motion2 feature. I would like to know, how are the real system requirements for a fluid motion in high bitrate m2ts (BD) and mkv files in 1080p.
With my config (Win Vista, AMD 4850e (2.4 Dual), integrated HD3200), I view choopy 720p files, and I would like to know if an ATI 5450 and/or AMD Athlon/Phenom Quad or Dual (what Ghz.) are sufficient for smooth playback and HD audio. Real experiences are the better.
Thanks.
sensei
PC Specification: i5-7200U, 8GB RAM, Win 10 x64
Re: System requirements for Picture2.
Mon Nov 15, 2010 4:03 pm
I have Phenom II 555 BE @ 3.9GHz + GeForce 210 and everything works smoothly (Win 7 x64).
tecram
Mon Nov 15, 2010 6:11 pm
Any other experience? Quad vs dual? Any admin report or processor comparison for frame interpolation?
Thx.
icsterm
Contact: Yahoo Messenger
Mon Nov 15, 2010 6:39 pm
i use an core i5 430M mobile cpu and Picture 2 at 10 setting eats 40% of total CPU resources.
aviwil
Wed Nov 17, 2010 7:12 am
icsterm - what video bitrate is this with ( when you click on I-information on lower left of window ) ?
tecram
Wed Nov 17, 2010 4:28 pm
It's sufficient with Athlon II X3 Triple Core or Athlon II X4 Quad Core vs Phenom II 555 Dual Core with Motion2 to 10, for example?
There would be sufficient with ATI 5450 Radeon when Motion2 is implemented for GPU?
Thx.
icsterm
Fri Nov 19, 2010 11:59 am
@ tecram
Have you read the Splash PDF manual?
It says:
CPU for Software HD Video Decoding
Minimum dual core Intel® 1.66GHz or equivalent
processor (SSE2 required)
GRAPHICS CARD
DirectX® 9.0c Compatible Graphics Card
ATI™ for GPU Hardware Acceleration
ATI Radeon™ 2xxx, 3xxx, 4xxx, 5xxx Series with ATI Avivo™ UVD support
Intel® for GPU Hardware Acceleration
Intel® GMA 4500 (chipsets: Q45/Q43), GMA X4500HD (chipset: G45), GMA 4500MHD (chipsets: GS45, GM45,GM47) with Intel® Clear Video support.
NVIDIA® for GPU Hardware Acceleration
NVIDIA GeForce® 8xxx, 9xxx, GT 1xx, GT 3xx, GT/GTX 2xx,
GTX 4xx Series with NVIDIA® PureVideo® HD support
For Picture 2 you will need a much faster CPU
tecram
Fri Nov 19, 2010 1:02 pm
icsterm wrote:@ tecram
Hello icsterm. Yeah, I read it. What I like to delimit is how much faster do I need?
Athlon II X3 or X4 or Phenom II X2 is required? Users can posts results.
Thx.
icsterm
Fri Nov 19, 2010 4:44 pm
Thx.
It depends if you play 720p or 1080p. For 720p any desktop Core 2 Duo CPU should work (AMD also, but you need higher clock rates). For 1080p you need a much faster dual core for smooth playback (quad core recommended).
Any AMD x3 or x4 CPU should work fine because Splash PRO is multi-core optimized.
sensei
Fri Nov 19, 2010 5:14 pm
Like I said, on my pc everything works smoothly (720p/1080p) with Picture2 ON.
