Bookmaster
PC Specification: i7 4790, GTX 1080 TI, Win 10 Pro 1803
Logitech c920 hd pro No Signal!
Sat Aug 25, 2018 8:31 am
It is possible that when trying to connect the webcam logitech c920 hd pro display the message No signal !, even though the webcam worked without problems in other programs.
This bug has been detected with version 9.02.61 of Logitech Gaming Software, since testing it in a previous version (8.96.81) did work.
To correct it, I had to do the following:
- Download the Logitech Webcam Software 2.80.853.0a from the official website: https://support.logitech.com/es_en/prod ... downloads#
- Install it.
- After installing it and trying the Action !, this one already recognized me the webcam, but the screen blinked in black several times.
- To which I had to reinstall the graphics drivers, in its latest version.
I hope that if someone else has this problem these steps will help you solve it.
I'm sorry if English is bad, but use the Google translator.
Re: Logitech c920 hd pro No Signal!
Mon Aug 27, 2018 8:16 am
Thank you for this information. We will check that out.
Deltavagita
PC Specification: windows 7
Contact: Website Skype
Wed Oct 02, 2019 12:27 am
Yep, got it all figured out now, everything is mapped directly in the game, no logitech software needed. The throttle works ok with the Extreme 3d Pro btw. Thanks
