mrbjaydubya
PC Specification: Intel Core i7, GTX 1070, Win 10
Screen Selection Issues
Thu Aug 30, 2018 1:21 pm
Hello;
I often use two of my 3 screens to record two separate instances of a single game (usually minecraft). One screen is my main account playing the game, and the second screen is from a camera account that is capturing timelapse footage.
I utilize the "Screen" capture mode as Game does not allow me to differentiate between two instances of the same game running.
The problem I am having is that I can get some game play recorded this way, but then the Active screen no longer functions properly by tying it to a single Desktop. At some point (and I've not been able to identify a particular event or sequence that triggers the problem) it goes from being a static selection to recording whichever desktop is active at the time.
The problem that that creates is that I need it to record a desktop that isn't active because that is the gameplay footage I am trying to capture (the camera account).
Again, it works fine for a while, but when it stops I have to fully reboot the machine.
A few things that would be very helpful:
- Either lock the Active Screen to a particular desktop ALWAYS if selected (I assume that is the intent, but it isn't working reliably)
- Allow the Application Selection to differentiate between two instances of the same program somehow.
- Allow the Game Capture Mode to differentiate between two instances of the same game running, somehow.
I could use Area Caputure Mode, but that is finnicky at best and a workaround that isn't very viable given that it's better at capturing a portion of a screen rather than a full screen.
Thank you!
Re: Screen Selection Issues
Fri Aug 31, 2018 6:57 am
Hello, so you are using Screen Mode to record selected screen but on some point you cannot swithc between screens, right?
Does Action! HUD disappear from other screens?
mrbjaydubya
Sun Sep 02, 2018 2:24 am
I want to record one screen while playing the game on another (I'm recording the timelapse of builds). However, the "Active Screen", even though I have it selected to a specific desktop, switches to whichever screen I am currently on. I need it to stay locked to one screen. When I change desktops in action, it doesn't indicate it (by turning blue) on the HUD.
This is intermittent. Sometimes, it works exactly as I want and let's me keep it locked to one screen. Also, it can't differentiate between two different instances of the same game; it would be helpful if I needed to select a specific game/program to have a [1] and [2] version.
Thanks!
Mon Sep 03, 2018 7:43 am
Do you play those games in fullscreen?
