_phantom_
PC Specification: i7 Lynnfield, EVGA GTX 570, Win 10 Pro
there are no audio tracks in premiere cc 2018
Thu Aug 30, 2018 10:37 pm
Original post Here
someone has some idea what happens with the action captures! and premiere CC 2018, when I drag the video clip to the timeline of cc2018 the audio track does not take me, but I have no problem in the cc2014 version ...
https://youtu.be/ORRyjMwgOyk
already asked in Adobe, but they did not answer,
and edit in another editing program, I have not tried in another. I manage more in premiere
Re: there are no audio tracks in premiere cc 2018
Fri Aug 31, 2018 7:40 am
Please provide us a MediaInfo report of your file. To do this please download (it's free) MediaInfo from here: http://mediaarea.net/en/MediaInfo. Once you have installed MediaInfo please go to your file location and right-click on it. Select MediaInfo. A new Windows with basic information should pop-up. Below you can find more information. Click the button and select "Tree" option. Advanced information will be displayed. Please export the report or simply create a screenshot of your Tree view.
_phantom_
Fri Aug 31, 2018 5:57 pm
General
Complete name : E:\_CAPTURA\Action!\Video\InitialD8_GLW_RE_SBZZ_redumped_ 18-08-2018 23-33-30.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 1.22 GiB
Duration : 3 min 17 s
Overall bit rate : 53.1 Mb/s
Video
Format : FICV
Codec ID : FICV
Bit rate : 49.9 Mb/s
Width : 1 360 pixels
Height : 768 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 FPS
Bits/(Pixel*Frame) : 0.797
Stream size : 1.15 GiB (94%)
Audio #1
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 36.2 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 10 ms (0.60 video frame)
Audio #2
Format : PCM
Codec ID : 1
Bit depth : 16 bits
Tue Sep 04, 2018 9:55 am
Make sure that adobe premiere pro is up to date.
Triexy
PC Specification: I7 2600k, Geforce 970, Windows 7 64bit
Sun Sep 09, 2018 11:42 am
Iam using Adobe Premiere too try mp4 as file format
