IDKBRO
PC Specification: INTEL CORE I5 GFORCE GTX 1050 12GB RAM
Action does not save the videos
Sat Sep 01, 2018 4:18 am
GOOD I do not speak English sorry if my English is something bad
The problem is the following:
I've been with this for almost 1 year now since I switched to windows 10 and went from Windows 7 to W10 in Windows 7 I had action and could record very quiet and it worked 100% but since I switched to Windows 10 LITERALLY ACTION DOES NOT work.
In other words, if it works, it loads the typical menu, but when I record the desktop screen or a game the video is not saved (I record in MP4 and AVI) and none works
Do not tell me to uncheck a certain box or all because I've been looking for Youtube and websites for a year now, and it does not work aboslutely. In fact, there are people who also have my same mistake and this hurts us a lot.
Because I am Youtuber and my friends also have not uploaded videos since 1 year ago because of this, I thought they would fix it in the middle of this year or so but nothing.
I do not know why this error is due but please solve it at once it is very important that you record with Action and start uploading videos as soon as possible
Basically Action in Windows 10 does not save me the videos, it does not process them, it says that it records and the folder where it saves videos, the .avi or .mp4 file appears to me and it weighs 0.0 MB. I mean it does not record fix it ok
I think I speak on behalf of thousands that this problem happens to them
Re: Action does not save the videos
Fri Sep 07, 2018 6:47 am
Click on, "Start Button".
Click on, "Run".
IDKBRO
Wed Sep 19, 2018 9:55 pm
Thu Sep 20, 2018 6:03 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
