Lykkal
PC Specification: i7-4702MQ/GeForce GT720M/Windows 8.1
Webcam not available/Help?
Tue Sep 04, 2018 10:12 am
Hello!
I use latest Action! 3.3.0.
I have purchased Action! through Steam.
This new version does not recognize my webcam. It doesn't allow me to select it.
But everything except Action works just fine.
Windows 8.1. Lenovo G710 notebook's webcam.
I already tried this twice:
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
Oh and also I tried to:
- Reinstall latest drivers for my webcam.
- Turn on "Record mouse cursor"
No effect at all.
So, I guess the problem is in Action itself.
But I really need the webcam. So that I need to do?
Re: Webcam not available/Help?
Fri Sep 07, 2018 6:59 am
Click on, "Start Button".
Click on, "Run".
Lykkal
Fri Sep 07, 2018 6:08 pm
For some reason, I can't attach DxDiag here. A message "Invalid file extension: DxDiag.txt" pops up when I'm trying to add it through attachments.
So I sent DxDiag to support@mirillis.com
The answer was:
"Maybe something takes control over your webcam and Action! cannot list it.
Try running Windows in a safe mode and see if it works there."
So, I wonder why Skype/Discord/OBS/Teamviewer and any other program can see my webcam and Action! isn't.
I suppose, Action! use odd method to get video devices's list.
By the way, problem still persists in 3.4.0
caspadan
PC Specification: Win10x64, i7-4770K, R9-280x, 16G DDR3
Fri Sep 07, 2018 7:44 pm
Hi, I'm sorry to "hijack" this thread, but my webcam has not been working since 3.2.0.
I'm using a Logitech C920. Mine is selectable, but nothing happens it doesn't work.
If I choose device as the capture mode and choose the webcam as the input device then go to preview, it just shows "No Signal".
Attached dxdiag info (remove .zip extension).
DxDiag.txt.zip
(108.2 KiB) Downloaded 798 times
Mon Sep 10, 2018 6:16 am
The answer was:
Have you tried running Windows in safe mode?
Mon Sep 10, 2018 6:22 am
Try installing this logitech software: https://download01.logi.com/web/ftp/pub ... lws280.exe
See if that helps.
caspadan
Mon Sep 10, 2018 5:43 pm
See if that helps.
Thanks, that did the trick for me.
languagelearner
PC Specification: Windows 8.1 - Intel Celeron G1610
Mirror image doesn't work in high video resolutions
Sun Nov 18, 2018 7:16 pm
I've been trying to record videos with Mirillis Action and the Webcam C920, but everytime I select any of the capture quality options on mirillis action, mirror image doesn't work, except when I select the "Default" one. Can someone tell me why this is happening?
