Splasher
PC Specification: Quad2.40Ghz;2GB Ram;Nvdia8800GTX;Win7x64
setup.exe unsafe?
Tue Nov 16, 2010 5:53 am
After i downloaded and activate the splash pro setupfile,
My AVG free edition detects malware.
i get a warning message, corrupted file
Is it safe to download and install Splash :?:
same problem occurs with lite version
i uploaded screenshot in attachment
Is it safe to download and install Splash?
Joco1114
Re: setup.exe unsafe?
Tue Nov 16, 2010 6:24 am
Maybe it's corrupted under the download process. What is the exact size in bytes? Mine is 14,498,520 bytes.
Home Theater:
Synology NAS 1010+ | 9TB HDD
Splasher
Tue Nov 16, 2010 7:16 am
14159KB
Joco1114
Tue Nov 16, 2010 7:30 am
Splasher wrote:14159KB
Can you tell me in bytes?
Home Theater:
Splasher
Tue Nov 16, 2010 8:11 am
14498816 Bytes?
i think it must be the downloadfile
i uninstalled AVG
it is not possible to unpack the file with winrar
Joco1114
Tue Nov 16, 2010 9:06 am
Splasher wrote:14498816 Bytes?
i uninstalled AVG
File size is not correct and you have to able to extract the EXE file with winrar. Maybe you have a virus or something. Try Avira (http://www.avira.com/en/avira-free-antivirus) or Microsoft Security Essentials (http://www.avira.com/en/avira-free-antivirus).
Home Theater:
Splasher
Tue Nov 16, 2010 9:39 am
no virus found after scan
but setup is still corrupted
Splasher
Tue Nov 16, 2010 9:12 pm
can you give a downlink to the correct file?
servocrow
PC Specification: Quad 9650 * 4gb ram * W7-64 * Nvidia
Tue Nov 16, 2010 10:28 pm
have no clue why AVG is calling it malware. its a false positive.
dont want to get into a cock fight over AV's however if you are already to drop AVG then you might want to try avast instead. MSE ran chaos on my machine, wasnt good.
Splash lite and pro are safe, been tested via Kaspersky, and ESET NOD 32. clean and clear.
Joco1114
Wed Nov 17, 2010 5:32 am
I checked and downloaded it again. My size is 14,498,520 bytes.
Try this direct link: http://mirillis.com/files/splash_pro_1_3_2_setup.exe
Home Theater:
