TheEliteDon
PC Specification: Intel® Core™ i7-4810MQ, GTX 870M, Win10
Can't stream properly
Tue Sep 18, 2018 1:56 am
Hello folks, I recently updated Mirillis Action to the latest version and everything is working fine besides the streaming function. My issue is I can steam while in desktop mode, but when in gaming mode trying to stream it doesn't work. I try hitting the hotkey and even manually and nothing.
Here are some of my specs
╔►CPU: Intel® Core™ i7-4810MQ (2.8~3.8GHz)
╠►GPU: nVIDIA GeForce GTX 870M 192bit w/3.0GB GDDR5
╠►HDD: 500GB Samsgun SSD / 1TB SATA III 6Gb/s 7,200 RPM
╠►OS: Windows 10 Home 64 bit
╚►RAM: (24GB) [1X] (8GB) Kingston / [2x] Crucial DDR3/1600 Memory
Re: Can't stream properly
Tue Sep 18, 2018 5:43 am
Does the issue occur in every game?
Provide us screenshots from followings tabs: Video Recording, Live Streaming.
TheEliteDon
Thu Sep 20, 2018 3:18 am
Last post probably won't be approved. Linked to imgur and just saw the attachments section, sorry.
Anyways, yes every game.
Streaming
Thu Sep 20, 2018 6:06 am
Can you at least record in a game mode? Make sure you open the game first and then use hotkey to start streaming.
TheEliteDon
Thu Sep 20, 2018 12:26 pm
Yes I can record in gaming mode, just no stream. I've done that and it doesn't work.
Fri Sep 21, 2018 5:46 am
Have you tried selecting YouTube or Twitch as a streaming serivce? Change this option from "custom" to "YouTube" and see if it works.
TheEliteDon
Sat Sep 22, 2018 2:59 am
Yes, both.
Mon Sep 24, 2018 7:40 am
Try resetting firewall settings. Open command prompt as an administrator and type: netsh advfirewall reset
TheEliteDon
Wed Sep 26, 2018 6:42 am
Nothing, but keep in mind when I'm in game it doesn't even activate. I also checked my AV and it's allowed though the firewall.
Thu Sep 27, 2018 6:00 am
So Action! doesn;t hook up to the game?
