Tonycubed2
PC Specification: 1080ti video, 7880 cpu, win 10 pro
recording 7680 x 1440 or 5760 x 1080
Thu Sep 20, 2018 6:39 am
Hi. I need to record surround video, which for me is 7680 x 1440. But your software sees the frame width as 4096 by 768, 1080p. Should be 1440p. It still records pretty good but when seen full screen it does not look right.
Any way you can add support for wide screen setups? Like 7680 x 1440 and 5760 by 1080?
Re: recording 7680 x 1440 or 5760 x 1080
Fri Sep 21, 2018 5:52 am
Hello. Even the GeForce RTX 2080 Ti is not able to encode in such resolutions in h.264. In other words, your recording is scaled by your graphics card.
You can try recording in AVI.
