Hellmut
PC Specification: Intel I9 9980X; SLI RTX 2080 TI; Win 10
Action! GPU acceleration problem (NVENC)
Mon Sep 24, 2018 5:30 am
Hello. After recent patch (3.3.0) users can choose GPU for recording (Added Nvidia GPU selection that will be used to perform hardware acceleration (available via Hardware Acceleration Settings in main screen). For me it was a disaster because program gave me 1-5 fps with huge image distortion. In the same time 3.2.0 - everything fine.
What should i do?
Re: Action! GPU acceleration problem (NVENC)
Mon Sep 24, 2018 7:51 am
Try updating or reinstalling your NVidia drivers.
Hellmut
Mon Sep 24, 2018 7:57 am
Already done it. No changes.
Mon Sep 24, 2018 10:25 am
Click on, "Start Button".
Click on, "Run".
Hellmut
Tue Sep 25, 2018 1:52 am
Ok. I cannot send file through attachments. Maybe Mega? https://mega.nz/#!2KoBzYga!dqDskp50-vLl ... deHiS4ECzo
Tue Sep 25, 2018 5:49 am
Download these NVidia drivers: https://www.nvidia.com/content/DriverDo ... type=TITAN
Start installation, select custom installation and uncheck all components leaving only basic graphics driver.
Select "clean install" option and install drivers. See if that helps.
Hellmut
Tue Sep 25, 2018 6:56 am
It did not help
Wed Sep 26, 2018 5:49 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
Hellmut
Wed Sep 26, 2018 8:40 am
No. It did not help. Problem is coming from separation GPU (NVENC GPU selection) somehow it ignores SLI after 3.3.0 patch. If I drop image quality - FPS will be steady.
Thu Sep 27, 2018 6:06 am
So the problem is that you have two graphics card in SLI and you have low fps, no matter which graphics card you select?
