Mr Spangles
PC Specification: i5 8600k / GTX 1080 / Win10 1803
Problem recording
Mon Sep 24, 2018 7:02 pm
Hello, I've recently had an issue recording in a specific scenario.
I think it began after the latest Action! update to 3.4.0.
Basically, I record gameplay of a racing sim called Assetto Corsa and use a launcher called Content Manager.
I also use Oculus Rift to race in VR and used the 'Game' setting to record it.
Action! used to record the desktop mirror of what I saw in VR, but it now seems to only want to record Content Manager, whether I choose 'Game', 'Area' or 'Screen'.
It also fails to work if I set the game to run on the monitor, rather than VR.
I've also tried to add Content Manager.exe to an exclude.txt with no luck.
I know it's a bit specific and you may not be able to help, but hey :)
My system specs:
OS: Windows 10 (1803)
Video Card: NVIDIA GTX 1080
Memory: 16 GB
Monitor Resolution: 1920x1080
Video Type: MP4 NVENC
Re: Problem recording
Tue Sep 25, 2018 5:56 am
Maku sure you have correctly added Content Manager to exclude list: https://mirillis.com/exclude-list-action-tutorial
Now, in a game mode, Action! shouldn't connect to this application.
Mr Spangles
Wed Sep 26, 2018 9:08 pm
Thanks for your reply.
However, as mentioned, I've already tried to add it to the exclude list.
Thu Sep 27, 2018 6:20 am
Try using my exclude.txt that you can find in attachment.
exclude.zip
(175 Bytes) Downloaded 766 times
