steen
PC Specification: Windows 7 - 64 bit
Stop recording after 1 minuts !
Tue Sep 25, 2018 10:43 pm
Use 3.4.0
After Update "Action!" stop recording after 1 minuts. The "Benchmarking" is diable and there is alot af space on the harddrive for til recording files.
Is the a log file I can open and se whats happens ?
Or what else can I doo ?
Re: Stop recording after 1 minuts !
Wed Sep 26, 2018 5:50 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
steen
Wed Sep 26, 2018 5:42 pm
Thanks. It's works.
Is it possibel only to recording audio without video ?
Thu Sep 27, 2018 6:10 am
Yes, it is possible.
Use audio recording feature.
