FallenTF
PC Specification: R5 1600AF, 1060 6GB, Windows 10
Separate Webcam codec / bitrate settings?
Thu Sep 27, 2018 9:16 pm
So I tried out the webcam recording feature (to record webcam to it's own file) while using NVENC MP4 for the game recording itself.
My 640x480 60 FPS webcam recording says it's using the FICV codec (yours) and 65.5 Mbps which is crazy high for just a webcam (the webcam file is bigger than my 1080p 60 FPS game recording using NVENC MP4).
Are there not any settings to use MP4 for the webcam instead? I don't see any, any setting changes don't effect the webcam codec / bitrate.
Other than this, the separate webcam feature is pretty nice.
Also, under my webcam settings, the "record separately" setting is missing the text (as seen in my attachment).
webcam settings.png (31.97 KiB) Viewed 7778 times
Re: Separate Webcam codec / bitrate settings?
Fri Sep 28, 2018 5:55 am
Hello, webcam is recorded in AVI for performance reasons. You can export webcam recording to MP4 using export feature in Action!
The problem with missing text should be fixed in next version.
