steen
PC Specification: Windows 7 - 64 bit
autostart
Thu Oct 11, 2018 8:22 am
Hi.
3 question.
Hoe can I make a setup there Action! Automatic stop recording the screen after x hour and x minuts ?
Can I setup Action! to automatic start and stop on specific time. ?
( start 10.00 AM --- stop 10.59 AM )
Can I setup Action! to not set the monitor in sleep mode then I'm recording ?
Re: autostart
Fri Oct 12, 2018 6:28 am
steen wrote: Hoe can I make a setup there Action! Automatic stop recording the screen after x hour and x minuts ?
Hello, use "duration" option to set recording time for Action!
Desktop 10-12-2018 8-11-18 AM-424.jpg (184.81 KiB) Viewed 6626 times
steen wrote: Can I setup Action! to automatic start and stop on specific time. ?
You can't setup Action! like that, but it is possible to do that by using batch files, scripts and task scheduler.
steen wrote: Can I setup Action! to not set the monitor in sleep mode then I'm recording ?
Action! is already doing that.
