MrCriticalRx
PC Specification: amd a10-8700p, amd radeon r6 ,win10 home
Action only load modules .
Wed Nov 07, 2018 7:43 pm
Action
Action Version: 3.6.0
Recording Resolution: Original, 1080p, 720p, 360p
Recording Mode: Game, Screen, Region
Windows and Hardware
OS: Windows 10
Video Card: amd radeon r6 graphics
Video Driver Version: 18.10.2
CPU brand and model: amd radeon a10 8700p
Motherboard brand and model: Asus k55dg
Memory: 8 GB
Monitor Resolution: 1366x768
Problem Description
Game/App Problem: na
Error Type: crash
Description: when try to open , only show loading modules . and when finish no open action menu
Re: Action only load modules .
Thu Nov 08, 2018 6:50 am
Click on, "Start Button".
Click on, "Run".
MrCriticalRx
Thu Nov 08, 2018 3:39 pm
Ok ,now i like try something , install action in other folder , how can make that?
DxDiag.rar
(14.19 KiB) Downloaded 919 times
Fri Nov 09, 2018 7:10 am
Your DxDiag log is showing Windows update failures. Do you have the latest OS updates installed? If no, please try installing all recent updates for your Windows distribution.
MrCriticalRx
Fri Nov 09, 2018 4:25 pm
i update a little fixes but nothing add new file
DxDiag.rar
(14.81 KiB) Downloaded 826 times
MrCriticalRx
Fri Nov 09, 2018 5:21 pm
ok y try and remove amd drivers and run action done, , and try whit old version amd and nothing ...
why ?¡
before that amd , no run good and try this https://www.youtube.com/watch?v=__Q0Vyt-JaQ and now amd run but now action no opened
and for record minecraft black screen before record normal i try this https://www.youtube.com/watch?v=fRTzvAb6AC4 and now is black in all recorder programs
Tue Nov 13, 2018 7:12 am
Try reverting default settings in Windows.
MrCriticalRx
Tue Nov 13, 2018 3:11 pm
now i restar all , action no open again , and i solveblack screen for record minecraft y trythis whit other recorder preograms (bad for my fps)
i think the problem is for the amd
any idea ?
Wed Nov 14, 2018 7:08 am
Download Radeon Software Adrenalin Edition 18.9.3 and make a clean install of it.
https://www.amd.com/en/support/apu/amd- ... -8700p-apu
aradralami
PC Specification: core i7, Nvidia geforce 1060,Win 10
Fri Apr 19, 2019 8:08 am
why ?¡
Hello friend,I did all the procedures as you mentioned in first video and the changes were applied, only when trying to click and open AMD Radeon Settings still does not open the window. Do you know what this is? I already verified that the changes are and yes, but it does not open. Greetings
