Sharur
PC Specification: Windows 10
Snap Action window to half of screen
Fri Nov 09, 2018 1:39 am
This is a Windows feature that I use all the time, but it seems to be disabled with Action (both the hotkey and snapping helpers at the screen edges). Is there a way to get Action to respect snapping?
Re: Snap Action window to half of screen
Fri Nov 09, 2018 7:15 am
Could you please describe the issue. Maybe provide us some screenshots of this problem.
Sharur
Fri Nov 09, 2018 1:54 pm
The issue is that, for example, if I hit Windows Key + Left Arrow with Action as the active application, it doesn't move to the left half of the screen. Other applications do (just about any application on Windows will do this). This is a feature that's been built into Windows since Windows 7. The settings in Windows 10 are located in Settings/Multitasking. I'm having trouble getting a good screenshot (which is only relevant for the window drag version, with the hotkey version there's nothing to see except the result), but there's plenty of images on Google if you search for Windows snap or Windows Aero snap or similar.
