DrunkMonk74
Action 3.7.0 - Sysyem Monitor Plugin
Thu Nov 22, 2018 8:37 am
Has anyone got the link the plugin for system monitor?
I've checked on the download page, (which only lists has Action 3.7.0 download). The same Action download page also says you should check the Facebook page for more info, but there is no information on the Facebook page about downloading the plugin, (other than what's on the Download page). So kinda stuck in a loop. Also checked the Twitter page for Mirillis and nothing there either.
Re: Action 3.7.0 - Sysyem Monitor Plugin
Thu Nov 22, 2018 10:26 am
It should be fixed now. Please check our Facebook page.
DrunkMonk74
Thu Nov 22, 2018 7:13 pm
Yep, thank you got the link.
Seems to work really well so far. I know it's beta so below are a couple suggestions (not criticisms):
  • monitor disk usage for a disk Mirillis is not installed on. I have Action installed on my C: drive, but my games are installed on my D: drive. I know alot of people do that.
  • a frametime graph or something similar
LoneStar
PC Specification: I7-9700K, eVGA GTX2080ti, Window 10 2004
Mon Sep 21, 2020 10:00 pm
Did Mirillis discontinue support for the System Monitor Plugin? It does not work on the current version. Any plans to add back in the future?
Thank You
LoneStar
Thu Oct 15, 2020 5:38 pm
Is there going to be a response to the questions I posted on September 21?
Fri Oct 16, 2020 5:48 am
Thank You
It works on our side. Go to Benchmarking tab and make sure to enable "Show system performance monitor" option.
F1L1P3
PC Specification: AMD FX-8350 Eight-Core, GTX1060, Win10
Tue Aug 10, 2021 7:10 pm
Hello, I got a Problem with the System Monitor Plugin.
my last Graphics Card was an AMD Radeon and I had all Information about the GPU (Temp and free Memory) inside the Plugin.
But since I upgraded to an NVIDIA GTX 1060, I can no longer see the Temp and Memoryussage of the Graphics Card.
Is NVIDIA not supported?
I already removed the Plugin and reinserted it + I already uninstalled Mirillis and reinstalled it, but the Problem is stil there
https://ibb.co/vv1XTmG
https://ibb.co/4S6qVGD
