ognjenmarcheta
PC Specification: i5 @ 3.50GHz 16GB 256SSD GTX570
No hardware acceleration on GTX570
Sat Nov 24, 2018 2:06 pm
Hi there,
There is issue with new version of action where it doesn't use my hardware acceleration. I saw it somewhere here on forum that you used some new technique from nvidia for recording that is supported on newer cards but you where apparently fixed that issue in latest version. Unfortunately this problem still exist on my graphics card.
I have latest drivers and did all other technical support steps you will tell me, I'm software engineer so let's skip that. :mrgreen:
Re: No hardware acceleration on GTX570
Mon Nov 26, 2018 8:36 am
Hello. GTX 570 graphics card was build in Fermi microarchitecture. This GPU microparchitecture does not support NVIDIA NVENC hardware acceleration technology.
ognjenmarcheta
Thu Nov 29, 2018 11:58 am
Thanks so either i should install older version that worked for me before, or it's time finally buy new card. :geek:
