ProJH
PC Specification: GTX 1080TI
[BUG] Changing export output folder
Sat Nov 24, 2018 9:37 pm
Everytime I try to change my export output folder Action! shutsdown and re-start itself. I believe there is a bug. I changed my hard-drive letter E to F months ago. I think Action! still didn't recognize the change. It still shows my old letter on textbox and the old direction (directory). I'm experiencing serious performance issue on BF5 while Action! is running. My output folder is on a HDD. I wanted to test it on my m2 ssd but I'm not able to due to this bug. I'm requesting a fix on next patch.
Is there a way that I can chance export output folder externally like using a config file ?
Re: [BUG] Changing export output folder
Mon Nov 26, 2018 8:40 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
