plixit
PC Specification: i7-8087k, GTX 1080 Ti, Windows 10 Pro
Problem with Audiointerface
Tue Nov 27, 2018 10:35 pm
while trying to record my gameplay I encountered an issue. My audio interface is listed twice as an audio input, but none of them works. I have a yamaha mg12xu with a usb interface in it. I just want to record the output of the mixer (obs has no problems with it). How can I fix that?
Thanks in advance
Re: Problem with Audiointerface
Wed Nov 28, 2018 7:22 am
If your audio interface is set default in your system then try selecting system default in Action!
plixit
Mon Jan 28, 2019 10:37 pm
problem seems to be fixed now
