Neyro
PC Specification: Intel Core I5 Nvidia GTX 1060 Windows10
Only one audio track on Sony Vegas Pro 16 is visible instead of 2....
Sun Dec 02, 2018 5:32 pm
Hello, recently I took a laptop (+ my PC) to work on my video editing...
So so I decided to export my Action! videos directly to my laptop and edit them on Sony Vegas Pro 16...
But only the system audio track is visible and the microphone track does not want to appear on Sony Vegas Pro 16 (i tried on my PC and on my laptop)....
My Action! settings are:
- Format: MP4
-Dimension: 1080p
-Fps: 60
-Recording: Bureau 1
-First source: Speakers (this is the system audio track)
-Secondary sound device: Microphone (Blue Snowball)
-And all the parameters below are not activated
You should also know that my videos work very well when I watch them on Action!
Re: Only one audio track on Sony Vegas Pro 16 is visible instead of 2....
Tue Dec 04, 2018 7:36 am
Please provide us a MediaInfo report of your file. To do this please download (it's free) MediaInfo from here: http://mediaarea.net/en/MediaInfo. Once you have installed MediaInfo please go to your file location and right-click on it. Select MediaInfo. A new Windows with basic information should pop-up. Below you can find more information. Click the button and select "Tree" option. Advanced information will be displayed. Please export the report or simply create a screenshot of your Tree view.
Neyro
Tue Dec 04, 2018 9:04 pm
Ok i opened one of my video where the problem is and that is what that appear :
General
Complete name : D:\Users\gabin\Desktop\Vidéo YouTube\A - Prêt au montage !\Action !\Action 02-12-2018 16-16-09.mp4
Format : MPEG-4
Format profile : Base Media / Version 1
Codec ID : mp41 (mp41/isom)
File size : 16.2 GiB
Duration : 1 h 21 min
Overall bit rate : 28.6 Mb/s
Encoded date : UTC 2018-12-02 16:37:22
Tagged date : UTC 2018-12-02 16:37:22
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4.1@High
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 28.3 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.227
Stream size : 16.1 GiB (99%)
Language : English
Codec configuration box : hvcC
Audio #1
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 96.0 kHz
Frame rate : 93.750 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 74.3 MiB (0%)
Language : English
Audio #2
Format : AAC LC
Bit rate : 128 kb/s
Stream size : 74.2 MiB (0%)
Language : English
Wed Dec 05, 2018 6:44 am
Sony Vegas has problems supporting mulitple audio tracks.
Try this: Open Sony Vegas location and go to FileIO Plug-Ins folder. Rename the compoundplug folder and see if that helps.
Neyro
Wed Dec 05, 2018 2:13 pm
I tried to rename it (to 'yooo') but it doesn't work, before that i make the update of October Action! and my Sony Vegas Pro 16 worked, do you think that it is possible to come back in a previous version of Action! ?
Thu Dec 06, 2018 9:44 am
I am pretty sure that getting back to older version won't help. But you can try version 2.8.2: http://downloads.mirillis.com/files/act ... _setup.exe
Neyro
Fri Dec 07, 2018 3:58 pm
You're right it doesn't help :/
Mon Dec 10, 2018 9:48 am
Open Sound Control Panel and switch to "playback" tab. Open properties of your main audio device, go to "Advanced" tab and change Default format to 16 bit 44100 Hz. Make a new recording and see if it works in Sony Vegas.
Neyro
Mon Dec 10, 2018 10:14 pm
Hey, i tried to set what you say but the problem still exist :/
I don't know why...
May i have to change my parameters ?
Tue Dec 11, 2018 7:37 am
Try recording using NVIDIA NVENC hardware acceleration.
