shadegr0wn
PC Specification: Windows 8.1, AMD FX-6350, 8Gb CPU
HUD is visible in Adobe Premiere
Sat Dec 08, 2018 11:28 am
Hello all!
I have the following problem:
After I finish recording my gameplay, the video in Action! preview window doesn't have HUD visible. However, when I import my recording to Adobe Premiere in order to edit it, HUD is there, visible and annoying.
I don't understand how it's even possible for HUD to be visible in Adobe Premiere while being invisible in Action! preview.
The only option I see in settings is to hide HUD completely from the screen, but in this case I will not be able to see if I am recording or not while playing the game.
Is there any other way to make sure that HUD is there while I record, but is not visible on recording?
Many thanks in advance and sorry if my English isn't good enough as it's not my first language :)
Re: HUD is visible in Adobe Premiere
Mon Dec 10, 2018 9:49 am
Close Action! or hide the HUD using F6 key.
