Hinasaky
PC Specification: Win : 10 , Nvidia GTX 1050
End Record = Forced Closed and Video Corrupt
Mon Dec 10, 2018 5:27 pm
Hello Team,
After i used this Apps for streaming, im really impressed.
So, after for a while i used this for livestream, i used it to record game w/o mic. and it going smoothly.
Then, I used again to record while im using discord with my friends, i already switch the mic to my earphone mic.
After it done, it happend. When i push stop rec, the apps suddenly restart itself and the my video cant be opened.
Then ill try to another, only 5 sec until 15sec , then the apps restart itself again.
After checking, i forgot to change the sound record to my earphone mic. Then the record is going better, but after record they still restart again.
Was it because of my external mic (earphone mic).
But, i run well when i do streaming with my external mic...
Any Idea ??
Regards.
Re: End Record = Forced Closed and Video Corrupt
Tue Dec 11, 2018 7:39 am
Please provide us sceenshots from following tabs:
- Video Recording (showing Primary Audio Device and Secondary Audio Device)
- Audio Settings.
Hinasaky
Tue Dec 11, 2018 12:38 pm
https://imgur.com/a/BrZLUHs
The attachment Setting audio 1.jpg is no longer available
- Audio Settings
The attachment audio.jpg is no longer available
-And here is what happend after software got restart , then i open it again :
Setting audio 1.jpg (169.19 KiB) Viewed 12244 times
Hope this can help, and thanks for the attention :)
Wed Dec 12, 2018 8:19 am
So Action! will crash if you record your headset microphone?
Click on, "Start Button".
Click on, "Run".
Hinasaky
Wed Dec 12, 2018 11:23 am
Here Is some Dxdiag data, i colliected from my laptop :
[attachment=0]System.rar[/attachment]
Hope this can help, let me know if u need something else
Regards.
System.rar
(17.09 KiB) Downloaded 783 times
Thu Dec 13, 2018 8:07 am
Try disabling Asus Sonic Suite and see if that helps.
Hinasaky
Thu Dec 13, 2018 12:36 pm
Im already unistal Asus Audio Wizard and its work perfectly.
Thanks for helping me out Piotr.
Problem Solved.
