Pounce2K
PC Specification: Intel I7-7600K, GTX 1080 & Windows 8.1
Quick Question
Fri Dec 14, 2018 2:53 pm
Hi all
Just wondering if it would be at all possible to increase the maximum bitrate for source resolutions in the streaming tab at some point in the future?
The only thing holding me back from streaming at 1440p (3440x1440) is that the bitrate of 20mbps isn't enough. If I was able to select up to 40mbps it may become a viable option. In the meantime, it's only viable to stream at 1080p at it's maxed bitrate setting. The streaming site I use does support 1440p streaming.
Allowing me to create a unique niche in the content I provide.
My internet speeds allow for 250mbps download and 50mbps upload.
My PC specs include:
Intel I7-6700K
GTX1080
32gb RAM
Windows 8.1
Otherwise I am limited to only showing 1440p content on pre-recorded video's on youtube. Which Action! really excels at, after years of searching this is the first product I have come across which can record excellent quality at high resolutions and at high fps. Best yet it achieves a good size to quality ratio, no more over 50gb videos anymore. Records 3440x1440 at 60fps with ease, I could record with 100fps with it easily too but that option doesn't exist as the next value is 120fps. However my Acer Predator Z35P monitor has a unique refresh rate of 100hz so that doesn't bother me. So from that point of view, I am very pleased with this aspect of the product.
Anyway many thanks for taking the time to read this.
Pounce2K
Re: Quick Question
Tue Dec 18, 2018 7:25 am
We might increase the max bitrate but there is no point doing that. No streaming service would accept stream with such a high bitrate.
