Yes!I disabled this settings.insect000 wrote:have you tried disabling Motion2 and Detail and Light Boost? enabling these features will take a toll on your CPU since these are post-processing features and will use the CPU, not the GPU.
what video formats are you trying to play in you computer?brev wrote:My friend! Yes I did.But result same! Splash pro doesn't turn on gpu support on my graphic card.
!!!!! Splash pro doesn't turn on gpu light on the left corner of program window.Look at left corner of your program.You can easily show your gpu indicator is light on.But my splash pro gpu indicator light off...
I used WMV(vc1),MPEG2 and some h.264 files.Generally 1080p,1080i or 720p.All players perfectly plays 720p content.But A little bit player perfectly plays 1080i or 1080p content.Windows media player perfectly plays 1080p VC1 content on my machine.CoreAVC codec perfectly plays 1080p H.264 content on my machine with any player.Nvidia pure video decoders perfectly plays 1080p MPEG2 content on my machine.But splashpro fails at this point.I think that splash pro has limited support on old gpus.Not optimized for 6600gt series.what video formats are you trying to play in you computer?
