RicYin
PC Specification: AMD Phenom II X4 955, Radeon HD 5850, W7
Exported video stutters/has green frames (SOLVED)
Tue Jan 17, 2012 3:46 pm
Today I installed the Action! trial after a friend recommended it to me.
The program works great, nice gui, causes low amounts or no lag and a clear recorded video.
However when i try to export a video it all goes wrong..
The exported video stutters heavily making it impossible to recognize anything (screenshot: http://db.tt/drpELn5j)
Also it has 2 stuttering frames, then 2 "green" frames until around 0:30min (screenshot: http://db.tt/mg55HHsp)
I have tried recording with a couple of different settings and all 3 recording modes but all give the same effect;
the recorded video is great, the exported video is unwatchable.
Any help would be greatly appreciated as i'm thinking of buying the full version if i can export.
Re: Exported video stutters/has green frames
Sun Jan 22, 2012 8:25 pm
Thank you for reporting problem.
Can you please check what video quality setting do you use (high, normal, low)
and check if problem occurs for all this settings?
RicYin
Re: Exported video stutters/has green frames (INVESTIGATING)
Tue Jan 24, 2012 12:38 pm
Thank you for the reply Ghost.
The problem occurs on all three settings.
I've also tried different output profiles, sadly that didn't change anything either.
Any other suggestions?
RicYin
Sun Jan 29, 2012 6:03 pm
I discovered my problem today when i tried playing the video in windows media player.
I was surprised to see that the video played normally in WMP and started playing with the settings of media player classic (my default media player).
I found out that MPC's default video renderer was my problem, a different renderer fixed it.
Thanks for the help!
Rick
Re: Exported video stutters/has green frames (SOLVED)
Sun Feb 26, 2012 9:26 pm
Thank you very much for keeping this thread updated!
Users browsing this forum: No registered users and 43 guests
