GamerTag9000
PC Specification: Windows 10 Home
Force Bit Rate and Bit Rate MP4
Thu Dec 27, 2018 8:42 pm
Hello, I have been searching for an answer to this question, but I have found nothing.
Can you explain the difference between Force Bit rate and Bit rate MP4?
Which is better for me?
I've tested it out for a simple Screen Recording and I didn't find a difference.
However, I tested out Force BitRate for an MMO game and it slowed my gameplay experience.
Re: Force Bit Rate and Bit Rate MP4
Fri Dec 28, 2018 7:08 am
There is no big difference between those settings. If you want to set specific bitrate for your video then use force bitrate option.
