not_leffen
PC Specification: i7 4790K, GTX 1080 SLI, Windows 10 1809
Action! 3.8.0 Stuttering
Fri Dec 28, 2018 1:42 am
Since updating to version 3.8.0, my recordings have been stuttering here and there. I've tried changing all sorts of things in my video recording and editing process and have narrowed it down to the recordings themselves having the stutters. To verify the issue, I reverted to the previous version, re-recorded the same video and the stutters were gone. Exporting the 3.8.0 recording using either version revealed stutters. Exporting the recording that came from the older version (again, exporting it using either version) revealed no stutters. If you need Action! settings, then here they are down below. Specifically, I'm recording Assetto Corsa at 1440p60 and am recording to a 500 GB Samsung 850 Evo:
File Format: AVI
Video Size: Original
Video Framerate: 60 FPS
Video Quality: Ultra
Use Multicore Rendering: Yes
Am I the only one experiencing this? Is this a known issue and a fix is on the way?
Desktop: Intel Core i7 4790K (delidded) 4.5GHz, 32GB DDR3 1600MHz, 2x Nvidia GeForce GTX 1080 FE SLI, 256GB Samsung 950 Pro (boot), 500GB Samsung 850 Evo (games and editing), 1TB WD Blue 7200 RPM (data), 6TB WD Black 7200 RPM (video library).
Re: Action! 3.8.0 Stuttering
Fri Dec 28, 2018 7:09 am
Hello, does the issue occur for other games? Could you please provide us video sample where your issue occur? Send original video file using Dropbox or Google Drive.
not_leffen
Fri Dec 28, 2018 7:26 pm
Thus far, Assetto Corsa is the only game I've recorded with the current version. The files are very large and I do not have the space in Google Drive nor Dropbox to upload them. I can record a few quick clips, but I don't think that'll be enough to capture the stuttering, as it usually takes a while for it to start.
not_leffen
Sun Dec 30, 2018 12:46 am
Here's one of the clips that exhibits the behaviour the worst. It starts less than 30 seconds in.
https://drive.google.com/open?id=1-PtRA ... lAxDS0zZp-
not_leffen
Sun Dec 30, 2018 9:33 am
One final update for the time being. It appears that the situation improves when I roll back to Action! 3.7.1. Version 3.7.2 exhibits the same behavior, so it seems that that's where the issue was introduced.
Wed Jan 02, 2019 8:32 am
I have exprorted your video using 3.8.0 version and I do not see stutters in the exported video.
not_leffen
Wed Jan 02, 2019 12:04 pm
I don't export my files from Action!, as I don't want H.264 or H.265 files. I edit with DaVinci Resolve and the Mirillis FICV codec is not supported in that, so I use Adobe Media Encoder to transcode the clips to DNxHR. I record at 1440p60 most of the time, sometimes dropping to 1080p60 if the scene I'm recording is too much for my PC to stay above 60 FPS. I've noticed that in recent versions of Action!, when recording at 60 FPS, Action! reports the framerate as 62 FPS, fluctuating a lot more than it used to. Again, this started around version 3.7.1-3.7.2 and has carried over into 3.8.0. Thoughts?
iztac
PC Specification: I5-3570K + 16 Gb DDR3 + GTX 1060 6GB
Wed Jan 02, 2019 5:54 pm
Hi, i had same problem but i tested to record on other HDD when result with 3.8.0 is perfect, when i compare the hdd , one is 5400 RPM (many drop 60 to 30 fps) and the other is 7200RPM (60 fps constant)... don't know if that can help you....
not_leffen
Thu Jan 03, 2019 7:10 am
I'm recording to an SSD, a Samsung 850 Evo, so that should not be in the issue.
bp1
PC Specification: i7 6850k, GTX 1080ti, 32 GB DDR4 Ram
Fri Feb 22, 2019 3:30 pm
File Format: AVI
Dude I'm having the same exact issue, I'm also recording on a Evo 850 SSD at 1440p60, with your same exact Action! settings, and my videos is having crazy jumps/stutters all over the place. I refuse to record in mp4 since the bitrate is way too low. PLEAE HALP!
