ertan.kucukoglu
Windows 8 Developer Preview - subtitle issue
Tue Jan 17, 2012 10:18 pm
I am using Splash Pro 1.12.1.
I just re-install my system from scratch in order to setup my RAID0 at last.
Previously, I had issues with subtitles are not shown. Appearing for some short miliseconds, and disappearing afterwards. That problem solved before. So, I tought at least after installing beta drivers for my display adapter.
I see now even I install same driver it does not work for pro. I have same exact problem continuing.
It doesn't help motion2 options on/off, or any other option. I believe, I tried them all.
Any additional information may required, I will gladly provide.
Thanks.
Ertan
mattisdada
PC Specification: i7 2700k@4.3ghz, nVidia 460 , 12TB* HDD
Re: Windows 8 Developer Preview - subtitle issue
Tue Mar 06, 2012 11:37 am
Well first off i would upgrade to Win8 Consumer Preview and still see if problem persists.
Secondly, is this happening with all videos or a specific video?
Thirdly, whats your graphics card and driver version?
The more information given, the easier it is for the community to help :)
