TOXiCiNK
PC Specification: i7-8700K, GTX 1080, Win10
Save Webcam video as separate file
Sat Jan 12, 2019 4:52 pm
Where is the webcam .avi file located? I have tried Time-Shift, normal video recording, lowering fps from 120, but still I can't figure out if the webcam file is saved somewhere or is simply not working. Where does the webcam video file get saved?
Re: Save Webcam video as separate file
Tue Jan 15, 2019 7:33 am
Webcam file is saved in the video output folder. During recording you should see two video files being recorded.
This option does not work when time-shift is enabled.
