Hinasaky
PC Specification: Win : 10 , Nvidia GTX 1050
End LIVE = Action! Forced Close
Sun Jan 13, 2019 3:48 am
Howdy,
Before December Patch. I do LIVE on Youtube and the result its great.
After, new patch... Yesterday, I did LIVE but, when i ended my LIVE, the apps will restart itself.
Is it ok ?
Thanks for the attention :)
Re: End LIVE = Action! Forced Close
Tue Jan 15, 2019 7:36 am
Does normal recording works?
Hinasaky
Wed Jan 16, 2019 6:53 am
Normal record, work fine buddy 😊
Wed Jan 16, 2019 7:12 am
Please provide us screenshots from following tabs:
- Video Recording,
- Live,
- Audio Settings.
Hinasaky
Fri Jan 18, 2019 3:10 pm
Here's some setting im using to LIVE and Record..
https://imgur.com/a/tynrVkj
NB : There is problem on record too lately, if i press RECORD button the apps will restart again. So, i can't record again now :(
Mon Jan 21, 2019 8:40 am
Click on, "Start Button".
Click on, "Run".
Hinasaky
Tue Jan 22, 2019 11:18 am
Here's some information you need :
Hope it will fix before Saturday , and no more bug,
Once again, thanks for your attention... :)
Regards
DxDiag.rar
(17.07 KiB) Downloaded 765 times
Wed Jan 23, 2019 7:09 am
Try disabling or uninstalling ASUS Sonic Suite if installed and see if that helps.
Hinasaky
Wed Jan 23, 2019 1:51 pm
Well,
I never using ASUS Sonic Suite or find ASUS Sonic Suite in my control panel, have any suggestion where is the location of the apps ??
The problem is same, I did the record smoothly but when i stop / save, it will restart itself
But, i find something might be the cause of the problem.
I always Save the Record on "REC" folder before this, then I make another folder named " Mirilis", after i closed the apps i erased the "REC" folder.
Then, i started the apps again.
But, "REC" folder is appear again, it appear when I stared the Action app, any idea ??
Thanks for the attention so far,
Regards,
Hinasaky
Wed Feb 13, 2019 3:46 am
Hy Guys,
Ill already solved the restart problem,
So, the apps might not support for Bluetooth earphone, after i changed my earphone (with usb / cable earphone).
All recorded, LIVE is smoothly again, i can choose all format , so i can edited easily.
Now i can back to record and LIVE again...
Great Job for all Mirilis Crew,
Regards
Hinasaky :D :D
