zicoz
PC Specification: various
Req: New ways to close the program.
Mon Dec 06, 2010 9:55 am
First of all I want to thank you for the auto full-screen implementation.
Then I have a request.
Is there any chance we could get an option to close the program with either "backspace" or "stop"?
This would remove the last function where one needs a mouse when using an MCE-remote for media playback, sure you'd still need it for the settings, but that's not really an issue since it's more of a one-time thing and not an issue in everyday use.
Would be great to just press a button on the MCE-remote to close the player when the movie is done.
The Mariner
PC Specification: Celeron E3300, nVIDIA GeForce 210, WinXP
Re: Req: New ways to close the program.
Wed Dec 08, 2010 8:32 am
... and for those of us who use a keyboard with a trackball, can I request you could also use the 'end' key ?
Regards,
Phil.
Regards,
Phil.
Sun Apr 10, 2011 9:55 pm
zicoz wrote:First of all I want to thank you for the auto full-screen implementation.
Hi, you mean to add the option (in example in settings) to make Splash close the application on playback stop command?
I assume that you open Splash from a different application (media center) and after playback stopped you want to close Splash and go back to this app?
The Mariner wrote:... and for those of us who use a keyboard with a trackball, can I request you could also use the 'end' key ?
Regards,
Phil.
We added a shortcut shift+x for closing application.
END sounds ok for this functionality but it is quite close to pageup/down
and im affraid it could be pushed accidentaly.
