lol
PC Specification: iMac 2016: cheapest model, windows 8 pro
video resising feature
Mon Feb 18, 2019 7:21 pm
please add resizing feature like video frame & pan & scan of mpc-hc.
ocd
H265 CPU Only Support, Video does not play, Only Sound plays
Tue Feb 19, 2019 1:00 am
Can you please include CPU support for x265 video like MPC-HC has when the GPU does not hardware support H265?
If playing a H265 video, only the sound plays. Tried to Unselect Hardware Acceleration and same result.
Would prefer if Splash can Detect H265 CPU only mode and still play the video with only CPU. MPC-HC does this task automatically but have Splash set as main player.
Thanks.
User's Whishlist
Tue Feb 19, 2019 7:18 am
Please use this topic to post your feature requests.
lol
Re: User's Whishlist
Tue Feb 19, 2019 1:24 pm
directx 11 & 12 support for rendering videos instead of evr.
Shaked
PC Specification: Windows 10
Thu Feb 21, 2019 12:32 pm
Please make the UI/UX better and I will explain:
1. match UI icons and interface look like action! 3.0
2. remove this useless button and instead replace it with pin button so the menu will be always visible to the people who wants it.
Link here:
https://ibb.co/c8C0C89
Moreover I would like to see better subtitle support like add ability to support effect and font subtitles.
and last please add timeline support for playback like VLC/MPC=HC.
lol
Thu Feb 21, 2019 5:01 pm
7.1 channel down mix to stereo support please.
Shaked
Fri Feb 22, 2019 7:39 am
Also forgot "about screen" so I will be able to see what version of the app I have and a button there for "checking updates" it is a basic thing
lol
Sun Feb 24, 2019 3:37 pm
ffmpeg codec plug-in support please.
lol
Sun Feb 24, 2019 4:16 pm
please support google's youtube webm (vp9/opus) format, because i download lots of youtube videos.
zomby7
PC Specification: 9900k, 2080gtx, 16gb
No HDR to SDR conversion
Thu Mar 07, 2019 2:12 pm
Can you please add this feature to your player?
When i watch a video which is decode in BT.2020 on my SDR Monitor the colors are flat.
Players like KMPlayer, VLC, PotPlayer change this automatically to the correct color spectrum of the monitor.
Greeds
Return to “Splash 2.0”
