crl2007
h264 in MKV not playing properly [FIXED]
Thu Dec 09, 2010 8:06 pm
It always freezes from time to time or it has artefacts. I thought it would be fixed, but since version 1.0.0 it is the same. I've uploaded a sample file for you to see and test.
With MPC-HC these type of files play very well.
Also, you should check your stream error handling. Sometimes it jumps 5 minutes instead of 1 second ( the stream error length ).
crl2007
Re: h264 in MKV not playing properly
Sun Dec 12, 2010 10:58 am
Any answer here ?
insect000
PC Specification: Intel Q8200, ATI HD 4770, Windows 7 Ult.
Tue Dec 14, 2010 11:19 am
Please post the MediaInfo output of your video file here.
crl2007
Tue Dec 14, 2010 11:41 am
No need, I already sent the files for analysis and the guys said that they experience the same behaviour and they are working on this.
Fri Dec 24, 2010 12:47 am
PLease check latest 1.4.0 version. Some problems should be fixed.
crl2007
Fri Dec 24, 2010 8:11 am
Thank you very much. Will check and report back.
LE: Works like a charm. All the samples I sent playback fine with 1.4.0. Thx for your quick response in fixing these issues.
