nambit
PC Specification: Windows 7
Option to change fullscreen resolution
Fri Dec 10, 2010 7:41 am
Any chance of adding an option to change the fullscreen resolution?
It would be great for those of us with HDTVs who use a lower resolution
for normal PC use (hey, I sit 17 feet away from the 60 inch Pioneer so I run
at 720P to read the text) yet would like to watch movies at 1080P without
changing the PC resolution all the time.
latino
Re: Option to change fullscreen resolution
Fri Dec 24, 2010 2:23 pm
wow, you got a 60" Pioneer plasma, you don't have the right to complain! :lol:
ontopic: this would be a good option indeed.
Sun Apr 10, 2011 10:07 pm
nambit wrote:Any chance of adding an option to change the fullscreen resolution?
We plan to add this functionality in the future, but I do not know if this will be available in PRO 1.x.x versions.
You can also try to set Windows DPI settings to 125/150% and check if this will work for you.
No need to lower the resolution then.
