i tried playing the file types you've mentioned (vob and m2ts) but on my end i can turn on/off Detail Boost and Motion2 independently from each other. i don't know if your problem is platform specific, i'm running windows 7 and splash pro and i have no problem turning on/off these settings. try changing the settings while playing the movie, not while being paused.bort wrote:Then why is it that if I uncheck the Motion2 box, the Detail Boost box is no longer checkable?
Whats your Windows version?bort wrote:Then why is it that if I uncheck the Motion2 box, the Detail Boost box is no longer checkable?
