Mortus
PC Specification: i5 2500, NVidia GTX 970, Windows 7 x64
MP4 using HEVC will only record one audio track
Mon Apr 01, 2019 9:51 pm
Version: 3.9.1
File Format: MP4
Hardware Acceleration: Nvidia NVENC HEVC
I have both a primary and secondary sound device set up, but it will not record the secondary device. I have tested with hardware acceleration disabled and using Nvidia NVENC and they both record both audio devices. The only workaround I can find is to record the secondary audio device as a separate audio file. Is this just a product of the HEVC or is there something else going on in my settings?
Re: MP4 using HEVC will only record one audio track
Tue Apr 02, 2019 6:23 am
Have you tried playing this video or does the issue occur in video editor?
Mortus
Fri Apr 19, 2019 1:51 am
Sorry, I completely forgot I had posted this. When I open it in VLC, I have to swap between the two tracks to get either the game or the microphone. I use Vegas Pro 15 for my video editing, and it only loads one track.
Fri Apr 19, 2019 6:07 am
It is the issue with Vegas Studio, but try the steps below.
Go to Vegas Studio's location and open FileIO Plug-Ins folder.
Rename the compoundplug folder to something else.
See if that helps.
Mortus
Sat Apr 20, 2019 1:51 am
Sadly that didn't work. I tried renaming and also removing the folder. I guess I'll have to use non-HEVC if I want to do hardware acceleration.
Users browsing this forum: No registered users and 54 guests
