I absolutely *WILL NOT* purchase it until it is supported.marfpilf wrote:Will DTS-MA ever be supported in Splash PRO?
It doesn'ticsterm wrote:How do you explain this? Splash PRO does support DTS-MA
I understand. I don't have any lossless equipment. Have you analysed the spectrals? Or the input on your lossless receiver reports a lower frequency? I believe very few have certified DTS-MA receivers or notice the diference. But yes, a true HD player should output all possible codecs up to 192KHz.nenco wrote:It doesn'ticsterm wrote:How do you explain this? Splash PRO does support DTS-MA
you obviously don't have any lossless equipment
receiver report plain dts, not dts hd, and hd audio led is off, so splash output only the core dts inside the dts hd:ma stream,icsterm wrote: I understand. I don't have any lossless equipment. Have you analysed the spectrals? Or the input on your lossless receiver reports a lower frequency? I believe very few have certified DTS-MA receivers or notice the diference. But yes, a true HD player should output all possible codecs up to 192KHz.
