lcf
PC Specification: i5-2500K, NV GTX 660, Windows 8.1 x64
Exporting recordings without rescaling - possible?
Sun Jan 22, 2012 10:55 am
Action! can record video in original resolution (for example WUXGA, 1920x1200) and play it using internal player, but I haven't found any way to export recordings to MP4/H.264 without rescaling.
Is it possible to keep original resolution when exporting? If not - is such as feature planned?
YouTube supports up to 4K (some examples here) - would be nice if Action! could follow.
Re: Exporting recordings without rescaling - possible?
Sun Jan 22, 2012 8:27 pm
Hi, currently exporting supports resolutions up to 1920x1080.
All higher resolutions are scaled down.
We consider to add support for higher resolutions in future versions
but theres no release date defined yet.
Soon we will add FIC export to uncompressed avi format so it will be also possible to convert it using 3rd party software.
Users browsing this forum: No registered users and 43 guests
