icsterm
Contact: Yahoo Messenger
Playback issue with MP4
Sat Dec 18, 2010 12:21 am
The following sample fails to play with Splash PRO. Here is the Media Info output:
General
Complete name : D:\videos\sample.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 23.0 MiB
Duration : 3mn 8s
Overall bit rate : 1 027 Kbps
Writing application : Lavf52.50.0
Video
Format : AVC
Format profile : High@L2.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 8s
Bit rate mode : Variable
Bit rate : 894 Kbps
Width : 540 pixels
Height : 320 pixels
Display aspect ratio : 1.688
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.207
Stream size : 20.1 MiB (87%)
Writing library : x264 core 83
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 3mn 8s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 2.87 MiB (12%)
Sample: http://www.mediafire.com/?s424ntroha4po51
Can the devs test the sample and fix this problem? It works fine with MPC-HC and iPhone.
Re: Playback issue with MP4
Sun Apr 10, 2011 10:00 pm
This should be fixed with latest PRO versions.
