abhaya
PC Specification: Intel Xeon X5650, GTX1060 6GB, Windows 1
Record mic to separate track doesn't work
Mon May 27, 2019 6:29 pm
OS: Windows10
Video Card: GTX 1060 6GB
Memory: 32GB
Monitor Resolution: 1920x1080
Video Editor: Vegas 16, Resolve, After Effects CS6
Game Problem: No game
Video Type: MP4
When I check option this option on Mic Settings, no sound is recorded, so I can't record audio to separate track. Please fix it, because compressed audio from mp4 is terrible, and I can't work with it!
Re: Record mic to separate track doesn't work
Tue May 28, 2019 5:54 am
What you should know about "Record microphone into separated audio track" feature is that it creates an additional audio track in your video file. It does not create any additional file. While you are playing back your video file you will hear only one audio path at time. To switch between active audio track please press "A".
